asif0012
[TempFolder] property doesn't work properly for the Installer Extraction Folder
I am using Advanced Installer 20.4 version, Enterprise Edition.
I want to extract the .msi and prerequisites files to the Temp directory. I am using the [TempFolder] to define the extraction folder path. But for extracting the installer files, the folder doesn't get created inside the "Temp" directory. It creates a separate directory beside the "Temp" directory by combining "Temp" with the manufacturer name.
The extraction folder path is given like here:
I am using the following location paths,
Bootstrapper Extraction Location Path: [TempFolder][|Manufacturer]\[|ProductName] [|ProductVersion]\install
Prerequisites Extraction Location Path: [TempFolder][|Manufacturer]\[|ProductName] [|ProductVersion]\prerequisites
Screenshot of the Temp directory during installation for the Extraction Folder:
Surprisingly, the same path works for the Prerequisites extraction folder. The folders get created inside the "Temp" folder. But for the Bootstrapper Extraction folder, it doesn't work. Creates the folder in the screenshot: "TempExtract" -> New folder beside Temp folder. The folder name is generated by combining "Temp" with the Manufacturer name.
Attached .aip file to generate the error:
ExtractToTempFolder.aip
(25.06 KiB) Downloaded 283 times
Best Regards,
Asif
Re: [TempFolder] property doesn't work properly for the Installer Extraction Folder
Hello Asif,
I have tested this with a sample project and I can indeed confirm the behavior.
I have forwarded this to our development team and hopefully this will be fixed in a future version of Advanced Installer. As soon as the fix will be released we will notify you.
asif0012
Hello Liviu,
I want to extract the install and prerequisites files in the Temp Directory.
I will use this feature with a future Advanced Installer version when it is available. But for now, is there any workaround to achieve the desired behavior? Can you please suggest me?
Best Regards,
Asif
Hello Asif,
I'm afraid I'm not aware of any workaround for the moment.
This has been fixed in version 20.7 of Advanced Installer, released on May 25th, 2023.
