AquaComm
Unable to find row with id:
I am creating a ".aisln" project in AI 20.6. After I closed the solution last night I keep getting the following error whenever I try to load it again:
I backup my files regularly and this project is no exception. If I try to open the project from within a mount of the backup it opens fine. If I then copy the backup to my working directory I get the same error again.
I have sent you the project via a separate email to your support address.
Help please.
Re: Unable to find row with id:
AquaComm
Restoring the project containing the error from a backup fixed this issue.
Unsure of how the issue was caused but I am guessing that saving the solution file without saving the individual project files as well may not have helped.
Thank you for your follow-up on this.
I'm sure this will help others facing a similar scenario to yours.
