Cagoo1961
Advanced Installer error in Windows XP
I added all the required DLLs to the installer even changed the framework to 4.0 so that the application works fine on Windows Xp. I executed the installer on Windows Xp and it gives me the error given the image above at the end of installation. How should I fix this ? Please help
Regards
Re: Advanced Installer error in Windows XP
I'm not quite sure why this happens.
In order for us to further investigate this, can you please send us by email to support at advancedinstaller dot com the following resources:
1. the .AIP (setup project) file
2. a download link for your setup package
3. an installation log
You can create an installation log by launching your setup package with a command line like this:
msiexec /i setup.msi /L*V "D:\installLog.txt"
when using an MSI package type, or a command like this
setup.exe /L*V "D:\installLog.txt"
when using an EXE package type.
