alco
Hyperlink on top of radiobuttongroup is not clickable
The hyperlink is placed on an empty space below the first radiobutton and above the second one.
These controls are placed on a new dialog that comes before the VerifyInstallDlg.
If I move the hyperlink to the left so that some text are outside the bounds of the radiobuttongroup, those text become clickable while the rest that are within the bounds are not.
Another odd thing is if the hyperlink is set as transparent, it ends up with a white background. Setting Transparent to False shows with gray background same as the radiobutton text.
Re: Hyperlink on top of radiobuttongroup is not clickable
I've tested your scenario, but I cannot reproduce the behavior.
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
alco
AIP file was sent by email.
