I'm afraid this is the default behavior of Windows Installer. Please note that the command line support to create the log file is handled by Windows Installer, which is designed by Microsoft. Windows Installer is not able to create a new directory for the log file.
This means that if you specify a log file location that does not already exist, the installer will not be able to create it and the logging will fail.
There is nothing we can do to control this behavior, because it is handled by Windows Installer. Only predefined folder systems can be used, any other folders will throw the error.
For more details, you can check the
Command-Line Options article.
- logfolder.png (67.88 KiB) Viewed 3904 times
I'm happy to help if you have any other questions.
