AquaComm
Unable to set permissions
I am setting this value :
I've tried everything I can think of without luck.
Help please :)
Re: Unable to set permissions
Can you please try to write only in the Username field (i.e. [GRP_EVERYONE]) and let the Domain field empty and see if this work?
If you want to set permissions for the Everyone group, the Domain field should not be completed.
Let us know if that helped you.
AquaComm
That was one of the many things I tried without luck.
Are you able to reproduce this on multiple machines?
If so, in order for us to further investigate this issue, can you please send us by email to support at advancedinstaller dot com the following resources:
1. the .AIP project file
2. a download link for your setup package
3. an installation log
If it is easier for you, you could create a sample project that reproduces this and forward it to us as well.
AquaComm
I suspect the issue was created because I selected "Keep Existing Permissions" and it was those permissions that were "incorrectly sorted". After sorting them it seems to have fixed it.
Thanks.
Thank you for your follow-up on this.
I'm glad you solved the issue.
