nickelnext
Error calling MSI API: 1627 Method: MsiDatabaseImport Table: ControlEvent. Extended Error:
I am getting the same error as many are in this forum
Creating MSI database (en)
Write Table IDT: 1: 2216 2: C:\Users\<<user>>\AppData\Local\Temp\BUIF97E.tmp\AITD843.tmp 3: ControlEvent.idt 4: 138 .
Error details
I was trying to put up a custom dialog with two checkboxes where the user should check them if he wants to install some additional software.
Looks like i got something done wrong and now it does not compile anymore
Can you please help me?
ObiScannerFrameworkInstaller203.aip
(201.94 KiB) Downloaded 236 times
Re: Error calling MSI API: 1627 Method: MsiDatabaseImport Table: ControlEvent. Extended Error:
Unfortunately, I cannot open your attached project due to its repository dependencies.
"C:\ProgramData\Caphyon\Advanced Installer\Repository\Dialogs\"
Therefore, in order for us to further investigate this, can you please forward to us all the necessary dialogs from the Repository so we can open your project? You can upload them here or you can send the files by email to support at advancedinstaller dot com.
nickelnext
Hi
Here it is
Repository.zip
(278.44 KiB) Downloaded 308 times
nickelnext
By the way i did not want to put naything on the repository but i did it by mistake and i guess thereìs no going back via the editor.
We can remove the dialog from the repository if it fixes everything
nickelnext
Write Table IDT: 1: 2216 2: C:\Users\nicke\AppData\Local\Temp\BUI6FCF.tmp\AIT6FD0.tmp 3: ControlEvent.idt 4: 138 .
Advanced Installer 20.7 build 173382f5
*** Stack Trace (x86) ***
[0x75998412]  RaiseException()
[0x02277b4a]  -----
[0x00f88e2d]  -----
[0x00f83f56]  -----
[0x00f9bba2]  -----
[0x00f9bf64]  -----
[0x00ed0da2]  -----
[0x00ed921c]  -----
[0x00d856c3]  -----
[0x00d85591]  -----
[0x00ece46b]  -----
[0x0107916b]  -----
[0x00b30944]  -----
[0x0095288f]  -----
[0x00794ac4]  -----
[0x018bd858]  -----
[0x76f42eae]  RtlFlsSetValue()
[0x7596e94b]  FlsGetValue()
[0x0227a34d]  -----
[0x02277030]  -----
[0x007acebe]  -----
[0x76657d59]  BaseThreadInitThunk()
[0x76f4b74b]  RtlInitializeExceptionChain()
[0x76f4b6cf]  RtlClearBits()
[0x002d0000]  MODULE_BASE_ADDRESS
The error occurs because there are duplicate actions on the Next button of the PrereqDialog dialog:
If you delete three "Execute custom action" events everything should work as expected.
You can find attached the fixed project.
(202.22 KiB) Downloaded 258 times
