asif0012
Windows Defender deleting the .exe installer file
I am using Advanced Installer 20.6 Enterprise Edition.
I have a .exe type installer built with Advanced Installer. I was using the installer without any issues. But after deleting a "Conditional Dialog" and then building the .exe file. When I copy it to a Windows 10 VM. I get the below virus detected and the .exe file gets deleted. If I just revert the change and build the installer, then the .exe doesn't cause any issues.
Deleting only a "Conditional Dialog" should not give virus detection. Is it a false positive for Windows Defender? How can I resolve this virus detection?
Machine: Windows 10 VM
Installer executable file size: 923 MB
Best Regards,
Asif
Re: Windows Defender deleting the .exe installer file
Hello Asif,
Is your setup digitally signed?
I have noticed a trend where Windows Defender flags your setup if it is not digitally signed.
Also, most likely, this is a false positive detection for which we can submit the files here: Submit a file for malware analysis.
asif0012
Hello Catalin,
The setup is not digitally signed. Will Windows Defender still flag my setup if I sign it using a self-signed certificate and make the self-certificate trusted on that machine?
I will use the following approach: https://www.advancedinstaller.com/digit ... guide.html
Best Regards,
Asif
Hello Asif,
If the setup is digitally signed, I would say that the issue will go away.
