colin.miller
Optionally install SQL Server Express 2017
In the past I have successfully installed SQL Server Express 2017 as a prerequisite, but I was wondering if it is possible to "optionally" install SQL Server Express 2017? The use case would be that they click a button on one of the dialogs and it automatically installs SQL Server Express 2017 onto the target machine with predefined parameters. Currently I have it as a custom action that runs the SQL2017EXPR.exe file with some command line flags but the problem is that it fails out instantly and never actually installs anything. Could I get some assistance with this? My command line arguments are as follows:
/q /IACCEPTSQLSERVERLICENSETERMS /ACTION=install /FEATURES=SQLEngine /INSTANCENAME=TestInstanceName /SECURITYMODE=SQL /SAPWD="testPassword" /SQLSYSADMINACCOUNTS="NT Authority\System" /ADDCURRENTUSERASSQLADMIN=True
Re: Optionally install SQL Server Express 2017
Hello Colin,
Starting with the Microsoft SQL Server 2012 Service Pack 2 (SP2), the SQL Setup can be installed as a feature-based prerequisite. This means you can condition its installation.
The SkipInstallerRunCheck command line parameter needs to be passed to the SQL prerequisite through the Install Command Line section of the prerequisite Setup Files tab in order to avoid the Windows Installer handle check of the SQL prerequisite.
You can add our "SQL Server Express 2017" predefined prerequisite as a feature-based prerequisite and pass the desired command line to it. Do not forget the SkipInstallerRunCheck command.
After that, you can add the desired condition for the prerequisite feature from the Organization page:
feature condition.png (56.19 KiB) Viewed 14282 times
In my case, the installation was conditioned by a Checkbox palced on a dialog.
For more details regarding the silent installation of the SQL Server Express, you can check our How to silently install the SQL Server Express 2019 Prerequisite into the main installation package?
article and the video tutorial: https://www.youtube.com/watch?v=O5Ch7-3fM4U
Let me know if you have any questions.
colin.miller
Thank you for the reply. I have since upgraded to v21.1 of Advanced Installer and it appears some things have changed. I added the SQL Server Express 2017 prerequisite as you instructed with the appropriate command lines but I do not see the corresponding feature in the organization page. Please advise. Also if you could update your screenshots to conform to the ui changes in v21.1 that would be helpful as well.
I'm afraid that with the new changes to Prerequisites support, SQL Server prerequisites are considered framework type and cannot be added to run as feature-based (during main package).
However, to overcome this, you can add the package yourself under the Main Package section (do not use our predefined list). You can add our predefined prerequisite and copy all its settings into a new prerequisite. After you add the prerequisite from our list, click on the "New Package from URL" toolbar button and copy with the Ctrl-C shortcut the URL and install conditions.
Do not forget to add the /SkipInstallerRunCheck parameter.
sql server.png (224.46 KiB) Viewed 12690 times
After that you can see the feature in the Organization page:
sql feature.png (161.31 KiB) Viewed 12690 times
