ShayanFiroozi
Windows Defender
I need to add my app executable file or its entire folder to the Windows Defender Exception list.
Thank you
Re: Windows Defender
I'm afraid we do not have predefined support for this.
However, you can easily achieve this through a custom action. For example, you can use a PowerShell script with the Add-MpPreference cmdlet.
Add-MpPreference -ExclusionPath 'C:\Temp'
This command adds the folder C:\Temp to the exclusion list. The command disables Windows Defender scheduled and real-time scanning for files in this folder.
For more details, please refer to the Add-MpPreference
article.
zander1989
Hey, Could you tell me if this will work after the installation to add the entire folder where its installed?
This doesn't rely seem to work :
Add-MpPreference -ExclusionPath '[APPDIR]'
Please note that I replied on the other topic you posted here.
