asdfasd
"Merge Modules" missing from left pane
Docs at https://www.advancedinstaller.com/user- ... dules.html suggest there should be a Merge Modules section under Requirements after Prerequisites and Launch Conditions but that's not what I'm seeing (in AI 20.8 or 20.9.1):
Running `regsvr32 mergemod.dll` in an admin prompt does result in apparent success:
image (1).png (22.18 KiB) Viewed 5193 times
Am I misreading the docs?
I'm also failing to find the Add Modules toolbar button described there. Any pointers appreciated. (I'm an AdvancedInstaller n00b; no hint too basic :) )
asdfasd
Re: "Merge Modules" missing from left pane
Comparing with another AI user realized that I needed to click "See All Features" to see "Merge Modules" in the left pane
Screenshot 2023-08-14 093434.png (29.25 KiB) Viewed 5181 times
It is indeed true that we have changed the UI a bit, as we tried to simplify the left view.
However, please remember that you can always use the "Search" bar:
