MGS
Combobox pre-select entry
I have a dialog with a combobox, which in turn has the property CB_PROP assigned. I fill that combobox and pre-select the first entry from a PowerShell script that I execute in the Init Events this dialog.
  • Filling the combobox works by assigning the AI_COMBOBOX_DATA to "CB_PROP|Value1#Text1|Value2#Text2" (and then afterwards calling the given PopulateComboBox custom action)
  • Assigning the first value of the combobox works by assigning the CB_PROP to "Value1".
Now, the "Value1" is correctly mapped to "Text1", thus "Text1" is displayed at the combobox IF the "Combo List"-property of the combobox is set to True. In my case, I need it to be set to False though and in this case if I set CB_PROP to "Value1", it is not mapped to "Text1" per default and instead "Value1" is displayed. If I now select the first entry manually though by clicking at it, "Text1" is displayed afterwards in the combobox.
Is there a way to make the combobox behave like I want, thus mapping the pre-selected "Value1" to "Text1" even if the "Combo List"-property is set to False?
Johannes
Re: Combobox pre-select entry
Hello Johannes,
Perhaps I do not quite understand your scenario here, because I've run a test just now and it looks like this is working as you'd expect with that attribute set to "false".
So the ComboBox has the following values assigned:
Upon running the setup, I can see that the values are mapped (if I sellect "test1", value "test123" will be displayed and if I select "test2", then value "test456" will be displayed)
