MGS
Execute PowerShell script before executing search
In order to read and update the values of a given XML file, we want to use this feature that you offer, which is quite neat: https://www.advancedinstaller.com/user- ... -file.html
But our problem is that we have a malformed XML file (multiple root nodes). I wrote a PowerShell script that fixes the XML file, but I need to execute this script before any search-functionality of the installer is executed, otherwise all the searches will fail as a result. How to achieve this?
Johannes
Re: Execute PowerShell script before executing search
Hello Johannes,
In order to achieve this, you can schedule your script before the Searches action group in the Custom Actions page:
ps script.png (93.16 KiB) Viewed 7920 times
Also, if the file is malformed when you import it, you can also try to fix it at build time by using the Build Events option. More details on the Use a Powershell script as a build event article.
MGS
Hello Liviu,
Thanks for the quick reply, that works perfectly, now my searches are executing without any error!
Johannes
You're always welcome, Johannes!
