JRowland
Relative paths
I have a project that I would like to save as a template but it is not working as hoped as the paths to all the source files look to be absolute and not relative, even though the project options is set to relative.
I have attached screen shots of the settings and the absolute paths.
Could you help me sort this out? Thanks,
Jonathan
Screenshot 2023-08-30 164602.png (15.7 KiB) Viewed 6705 times
Screenshot 2023-08-30 164827.png (54.02 KiB) Viewed 6706 times
Re: Relative paths
Hello Jonathan,
Could you please take a look over the following thread and let me know if it helps?
Re: Change physical source to relative path
(you can read it from the start if you'd like)
From what I can see, you do not have the path converted in your project and therefore the above thread might help.
JRowland
Re: Relative paths
Thanks, I did get there eventually and managed to convert the project to use appropriate paths.
As a follow up I did end up with a bad template and cannot see how to delete it, is that possible?
Thank You,
Jonathan
Re: Relative paths
Hello Jonathan,
I am glad to hear you managed to get this working!
Regarding your latest quesiton, please note that the templates are saved in the following location:
C:\ProgramData\Caphyon\Advanced Installer\Repository\Project Templates
If you go to that location, you should be able to remove the template.
