benjamin.batman
SQL Server Express Prerequisite gets stuck installing when the setup is created in 20.9 - 21.0
Hey,
Every since upgrading to 20.9 or newer, the SQL Server Express Prerequisite freezes during installation. I have noticed this with multiple SQL Server Express prerequisites. If I copy the EXE file from the prerequisites folder and try to run it manually in command line with the same arguments, it installs fine.
Command Line: /qs /IACCEPTSQLSERVERLICENSETERMS /ACTION=Install /FEATURES=SQLEngine /INSTANCENAME=SQLEXPRESS /UpdateEnabled=False
Benjamin
Test Application.aip
(25.78 KiB) Downloaded 310 times
Re: SQL Server Express Prerequisite gets stuck installing when the setup is created in 20.9 - 21.0
Hello Benjamin,
This is a known issue. Can you please check the [Version 20.9.1] - Issues with the Microsoft Express 2019 pre-requisite installation forum thread discussing the same scenario.
This issue has been fixed on our side, but unfortunately it did not catch our latest release, Advanced Installer 21.0.
I have forwarded the fix to you via email.
Hello Benjamin,
This has been fixed in version 21.1 of Advanced Installer.
Codename K
I tried to install SQL Server 2022 Evaluation (Enterprise) as a prerequisite before the main installation. But it gets stuck at the middle. However, if I close the main installer, then it continues the SQL installation. What is the issue here? How to fix this?
Advanced Installer Version is 22.1
Source: viewtopic.php?t=53315
K
Codename K
This solution worked for me: viewtopic.php?p=131260#p131260
Adding command line argument
/SkipInstallerRunCheck
to SQL worked.
K
Hello K,
Good to hear that everything is now working as expected.
