stacyirish
Do not show Azure Key Vault Secret in Jenkins build log
Hello.
After asking a previous question about how to digitally sign an Advanced Installer package in a Jenkins pipeline (script), I implemented the use of the command file from a script as shown:
AdvancedInstaller.com /execute <path_to_project_file> <command_file_path> [-nofail]
However, this outputs the secret text directly into the build log which does not keep the secret very secret at all. I've tried to use the environment variable option in the command file by creating a System level environment variable named "AzureKeyVaultSecret" and using it in the command file as such:
SetAzureKeyVaultSecret AzureKeyVaultSecret -secret_is_env_var_name
This does not seem to work, though, and results in the following log:
>AdvancedInstaller.com /execute TestProject.aip aicommandfile.txt
Save
Rebuild
Checking builds status
Build required.
[ DefaultBuild ]
Building package: [...]TestProject_Setup.exe
Prepare build
Detecting MSI incompatible resources
Preparing files
Unable to get Azure Sign token. AADSTS7000216: 'client_assertion', 'client_secret' or 'request' is required for the 'client_credentials' grant type.
Trace ID: 358c3bee-a3d7-417e-a578-6486db90c100
Correlation ID: 6d87449a-8c93-4ba0-8087-2b163ec1b750
Timestamp: 2023-09-13 23:17:54Z
Is there any way to digitally sign an Advanced Installer package via a Jenkins pipeline script and keep the Azure Key Vault Secret a secret?
Any help is appreciated.
Re: Do not show Azure Key Vault Secret in Jenkins build log
First of all, please accept my apologies for the delayed reply - some of our colleagues are on sick leave and this resulted into a delay in response time.
Regarding this, please have a look over the following article:
Configure a Digital Certificate in a Jenkins Build Step: Jenkins Credentials and Azure Key Vault
point 2.1 and 2.2, which I think is exactly what we are looking for here.
