gopinathrbe
Uninstallation error
I have attached the installer project created with the latest version, 21.0.1, on Windows 11. I am facing the following issue: after installing using a command line (Test.App.exe /exenoui /qn), uninstalling from 'Programs and Features' shows the following error message.
Test.App.aip
File doesn't have any resource referenced.
(33.29 KiB) Downloaded 857 times
Re: Uninstallation error
Thank you for bringing the issue to our attention.
I've been able to reproduce it. It seems to be generated by the Enhanced User Interface option from the Themes page.
I have forwarded this to our development team and this will be fixed in a future version of Advanced Installer. As soon as the fix will be released we will notify you.
We understand the impact it has on your experience, and we are committed to delivering a resolution as quickly as possible.
We apologize for the inconvenience and appreciate your patience.
gopinathrbe
Is it fixed in the latest release?
We will let you know when this issue is resolved.
Most likely, the fix will be included in our next release (v21.2).
This has been fixed in version 21.2 of Advanced Installer.
gopinathrbe
The output .exe has been detected as virus by Kaspersky Antivirus
Most likely, this is a false-positive detection.
What I would suggest is adding the output folder in your project as an exception to Karspersky and then, before delivering the setup to your clients, submit the file for whitelisting - this shouldn't take much considering it's a false positive.
