I've looked over your project and I noticed that you use the "https_port" property for the port number in the "Bindings/SSL" tab. Please note that the binding from that tab and the one from the "Custom Properties" tab must be identical, otherwise it will not work.
Therefore, you need to use a port value or the same port property for the bindings from both tabs. If you want to use the "https_port" property, you need to configure the custom property as shown in the image below:
- Binding Port Property.png (14.04 KiB) Viewed 148000 times
Let me know if this helped.
