it@dock2dock.io
Signing with Digicert Keylocker
I trying to sign with Digicert keylocker using a custom signing tool and Advanced Installer 21.0.1, using the following command:
smctl sign --verbose --keypair-alias key_xxxx --input
I am getting this error:
“Win32 Error [2148204800]: "No signature was present in the subject. "
Error details
Build finished because an error was encountered.”
When I run this command in the terminal the file is signed.
smctl sign --keypair-alias key_xxxx --input C:\Downloads\test.js
Re: Signing with Digicert Keylocker
Please note that I have answered to your email.
If possible, please try avoiding duplicate threads (i.e. posting on forum and emailing our support address as well) as that can lead to multiple team members working on the same ticket.
dstroyrx
I have the same issue. Can you share the answer here for myself and others who might come across this thread?
Can you please confirm that signing works as expected outside the Advanced Installer e.g. in terminal?
We were able to workaround this error by using the SignTool for signing. Note that you need to download a copy of the certificate.
Import the public key of the certificate to the Certificate Store (e.g. Personal Store).
After this, the command line from Advanced Installer can be something as:
sign /csp "DigiCert Signing Manager KSP" /kc key_509256942  /f C:\Users\DemoUser\Downloads\cert_509256942.crt /tr http://timestamp.digicert.com /td SHA256 /fd SHA256
DigiCert custom SignTool.png (83.44 KiB) Viewed 43310 times
Let us know if using the SignTool worked as expected.
Cams1337
This does not work
Thank you for the followup on this.
Let's continue the discussion on the other thread we have going on.
