asif0012
How to create directory same as ProductName in the ProgramMenu to store the shortcuts
I want to create a folder with the same name as the "ProductName" property under the "ProgramMenu" folder. The name of the folder will come from the "ProductName" property. I want to keep the shortcuts of the project in this directory.
How can I achieve the above functionality?
Best Regards,
Asif
Re: How to create directory same as ProductName in the ProgramMenu to store the shortcuts
Hello Asif,
In order to achieve what you need, we first need to create a property in the "Properties" page, e.g.:
We can then create a property based folder based on this property and a "Set property" custom action to set the value of the property to what you need:
Hello Asif,
As a followup, an easier way to achieve what you need is as it follows:
