sobomsawin
IIS Browse SSL Binding Empty Data Output
I am using AI 21.0.1 and I need to display a list of IIS Web Sites (along with the bindings) from which the user can select under which web site the application should be installed. Now the Web Site Browse allows to return different information in variables under the Data Output section. this works correctly for the HTTP binding of a Web Site, but doesn't work for HTTPS binding. Is there a way to make this work for both bindings?
See attached test project and screenshots.
Thanks.
Variable Values 1.png (23.11 KiB) Viewed 5765 times
Selected binding 2.png (11.05 KiB) Viewed 5765 times
Variable Values 2.png (23.09 KiB) Viewed 5765 times
Re: IIS Browse SSL Binding Empty Data Output
I'm not sure why this happens.
To facilitate a more in-depth investigation of this issue, can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com?
