asif0012
How to enable back button in the "WelcomePrereqDlg"
I am using Advanced Installer 20.8 Edition. I am using the Surface Theme.
In my installer, I have the LanguageDlg to select the language. I want to have a Back button from the WelcomePrereqDlg which will take the user to the LanguageDlg. I haven't found the LanguageDlg in the dropdown of the "Display a specific dialog" published event.
Screenshot 2023-10-26 141431.png (362.34 KiB) Viewed 10686 times
How can I achieve this functionality?
Best Regards,
Asif
Re: How to enable back button in the "WelcomePrereqDlg"
Hello Asif,
I'm afraid it is not possible to achieve that, due to a limitation that only allows the language to be set at start.
If you have any other questions, please let me know and I will gladly assist.
