sirosimous
Dynamic Features based on folder/file discovery.
I need some help creating a dynamic installer of potential available features.
My application contains a lot of optional features that are in 2x categories (CatA and CatB)
So far I created the Main Feature, Feature A and Feature B.
The available features under A and B will depend on the available sub-feature folders in the feature source folder ( _sourceFeatureA and _sourceFeatureB folder ).
Each sub-folder will contain the components (mostly DLLs) that will constitute a sub-feature under Feature A or B.
All features under A or B will be deployed towards a single folder ( destinationA or destination B)
The user should be able to choose which features to install.
For instance:
- _sourceFeatureA/FeatureA1/a1.dll will create the FeatureA1 subFeature, deploying a1.dll into destinationA folder
- _sourceFeatureB/FeatureB1/b1.dll & bRoot1.dll will create the FeatureB1 subFeature, deploying b1.dll & bRoot1.dll into destinationB folder
If it makes sense…. ;)
I have been able to create such architecture but it was all pointing at already known files. I’m not sure how to do it when I don’t have a definition of the sub-feature in advance.
I also read about Synchronized folders but I’m not sure how to automatically create feature out of the discovered folders/files and may be a template feature ??
Thank you for your help
Re: Dynamic Features based on folder/file discovery.
If I understand what you need to achieve correctly, then indeed the Synchronization feature is what we can look at.
However, as you have mentioned, you would need to at least have the subfeature created in advance, so you can add the files under that specific feature when they will be generated on disk:
sirosimous
Thank you for the confirmation. Is there any way to create sub-features through scripting ?
Ultimately, the installer build will be realized in Azure Dev Ops through release pipeline, so another approach I thought about would be to use merge module instead. Each of my sub-Feature could create its own merge module, then each module would be transferred to the main installer project.
Is it possible to load Merge module in each FeatureA and FeatureB folder, synchronize the Feature folder so it dynamically add all the module ?
Is it possible to have the user picking what module have to be installed ?
Or does the selection, always linked to the Feature object ?
You are always welcome!
Yes, you could achieve that through the New Feature Command Option
Not quite sure I fully understand this. The merge module is indeed tied to a feature.
This could be done by giving the user the possibility to choose which features to be installed and therefore which modules.
How to conditionally install a prerequisite based on the user selection?
(Ignore the prerequisite part, focus on the "feature" part)
