enhl
Powershell script run as Admin Set-ExecutionPolicy Remote Signed
Hi team,
1) Place zip file in set location e.g. C:\Users\xxx\Downloads
2) I need to open Powershell as administrator, then these 2 commands in the directory
a) Unblock-File -Path <path-to-powershell-installation-script>
b) Set-ExecutionPolicy RemoteSigned and answer A
c) I place powershell (ps) script in same directory where the zip is and execute ps script i.e. .\<path-to-installation-script>
Re: Powershell script run as Admin Set-ExecutionPolicy Remote Signed
I'm afraid I do not quite understand your scenario here and what you're trying to achieve.
If possible, could you please give me some more details (with screenshots from your project)?
enhl
Hi Caitlin,
I am unable to attach screen capture to this post, when I add an attachment, it shows an error.
I was hoping that Advanced Installer could help me with either Option 1 or 2
Option 1:
Help create a MSI installer that would one click execute a powershell script that needs the contents of the zip folder for installation.
My current manual steps
MS installation would need to
2) Execute Powershell script in administrator mode. Prior to powershell script execution I usually need these 2 commands
b) Set-ExecutionPolicy RemoteSigned and answer A -> for the above commands, does Advanced Installer have ways for these
c) powershell script needs to execute in same directory as the zip
Option 2:
I created a .exe based of the zip and the powershell script. It is currently one click execution, just needs the user to place it in any directory and run in administrator mode.
How do I create a MSI off the .exe and the MSI will run the .exe in administrator mode, because the powershell script within the .exe needs it.
Thank you for your follwup on this and for sharing the details with me.
Now I understand what you are trying to achieve.
So, in order to achieve that within Advanced Installer, we can proceed as it follows:
- create a new project
- in the "Files and Folders" page, select the location where you want the ZIP archive to be extracted and add the ZIP there
Path to folders in the Files and Folders page
- you can then go to "Custom Actions" page and add an "Inline PowerShell script" custom action after the "Add resources" action group
- for this custom action, set the "When the system is being modified (deferred)" and "Run under the LocalSystem account with full privileges (no impersonation)" options
- input the custom action code
Note: we would need here to either get the path of the ZIP or use Powershell's Set-Location cmdlet to set the location to the folder where the ZIP resides.
- build&run the setup
enhl
Hi Caitlin,
I followed the steps but it doesn't seem the powershell script gets executed. Would you have a step by step video or tutorial that I could follow.
I'm afraid there isn't any step-by-step guide for this.
If possible, could you please forward me a copy of your AIP file and a download link for your setup by email at support at advancedinstaller dot com so I can further assist you here?
