gopinathrbe
Extracting LibraryKey
Is it possible to extract the Library Key using the command line or PowerShell?
Re: Extracting LibraryKey
I'm afraid not.
However, I will add this on our TODO list of improvements and hopefully it will be added in a future version of Advanced Installer.
gopinathrbe
Any updates regarding this one?
This has not yet been implemented.
However, I have now increased its' priority and hopefully it will be added in a future version of Advanced Installer.
This improvement has been added in version 22.2 of Advanced Installer.
gopinathrbe
"Do you have a sample of how to access that?
Sure thing, here is an example of how to retrieve the LibraryKey.
$advinst = new-object -comobject Advanced Installer
$proj = $advinst.loadproject("your project path")
$licensing = $advinst.Licensing
$libkey = $licensing.TrialsAndRegistrations.Registration.LibraryKey
The $libkey variable will now contain your LibraryKey.
gopinathrbe
How can I access multiple trials?
How do I add a trial using PowerShell?
How can I read TrialwareName, Password, PrivateKey, PubKey, and LibraryKey?
Do you have any documentation regarding these properties?
Not quite sure what you mean here. Could you please give me some more details?
Regarding the rest, yes, there is documentation available here:
Advanced Installer PowerShell Automation Interfaces
ILicensing
ILicenseTrialRegistration
gopinathrbe
Here is the file with multiple trials?
gopinathrbe
what about TrialwareName, Password, PrivateKey, PubKey, and LibraryKey?
The LibraryKey is available by accessing the "Registration" property, like this:
$proj.Licensing.TrialAndRegistrations.Registration
Regarding the others, I'm afraid they might not be available just yet.
gopinathrbe
gopinathrbe wrote: ↑Fri Apr 11, 2025 10:05 am Here is the file with multiple trials?
this one?
Not quite sure I fully understand your request here.
Are you asking how to add multiple trials from PowerShell?
gopinathrbe
I want to get the LibraryKey from multiple trial configurations.
powershell
Copy
Edit
$advinst = New-Object -ComObject AdvancedInstaller
$proj = $advinst.LoadProject("your project path")
$licensing = $proj.Licensing
However, it’s unclear how to access LibraryKey values if there are multiple trials defined.
