finnegerd
Auto numbering registry value if same already exists
I try to create an installer for my Excel-Dna UDF. In the current situation, if I set my registry value as OPEN (I have to name it like this according to Microsoft registration rules) and if there is already a value having the same name (another OPEN), my registry file overwrites it.
How can I set the installer to dynamically rename my registry value as OPEN1 automatically if there is OPEN already. Is it possible? Plus, the installer should also remember this dynamically created name (OPEN1) to find it during the uninstallation process.
Thanks.
Re: Auto numbering registry value if same already exists
There are multiple ways of achieving what you need.
What I'm thinking is this:
- have a property with the "none" value defined in the "Properties" page
- in a script Custom Action (e.g. PowerShell), we can look for the registry you mentioned:
1. if the value exists, set the property to value OPEN1
2. if the value does not exist, set the property to value OPEN
Have this custom action scheduled after the "Searches" action group in the "Custom Actions" page.
finnegerd
Thank you for your prompt reply Catalin.
Using powershell script, I succeeded to determine whether there is already "OPEN" or not and set it to a property as you describe.
And placed this custom action after "Searches" action group as below.
Then I assigned my custom property's value to the name of value in Registry page as in below. It worked !
registry value.jpg (119.46 KiB) Viewed 17059 times
I am glad to hear everything worked. :)
