hiroyuki hara
Installation error in VM environment
When I run the exe that I created using Advanced Installer in the following environment, an error occurs.
 vSphere Client version 7.0.3.01700
 VMware tools version 12.3.5
 Virtual OS windows server 2019
The error is as below
AI_WinOptFeaturesConfig returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Is it better to repack in a VMware vSphere environment?
Re: Installation error in VM environment
It is not quite clear to me when this error occurs.
Does this occur after you repackage an app using Advanced Installer and then try to install the package resulted after building your Advanced Installer project?
The error you mentioned would indicate an issue with the installation of a feature ("Prerequisites" page --> "Windows Features").
