MercuryMage
Inline PowerShell can't pass or access properties
Following multiple guides and posts and neither is working for me. Included screenshot.
Here is the Parameter values text:
"--productName [ProductName]"
Here is the script code:
Param($productName)
echo $productName
$appDir1 = AI_GetMsiProperty APPDIR
echo $appDir1
MercuryMage
Re: Inline PowerShell can't pass or access properties
Output:
Return code: 0
Script output: "--productName
Please take a look at our Getting a property value into a script (for deferred custom actions) article.
-firstPsParam [FIRST_MSI_PROP]
If your property contains spaces, you must include it in quotation marks:
-productName "[ProductName]"
If you still can't get this to work, please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this.
MercuryMage
My PowerShell version was 6, does this make a difference? I installed PowerShell 7 alongside but when I check $PSVersionTable.PSVersion in the inline PowerShell Action, it still says 6. How do I change the version it points to?
MercuryMage
Sorry, I'm on version 5 upgrading to 7
MercuryMage
Here's the aip file
SIMS-Installer-AI.aip
(14.41 KiB) Downloaded 1079 times
MercuryMage
I see it's not the version, sorry, bad day
MercuryMage
Please ignore and I apologize, I figured out the issue.
We are glad everything is working as expected.
