Brian Modra
Disconcerting use of Software\Microsoft\Windows\CurrentVersion\Uninstall
I noticed that in my AIP file there are some properties based on
Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]
which are then used in other parts on the AIP. E.g.
<ROW Component="DisplayIcon" ComponentId="{1BDAC750-36E0-428C-8A10-874BBA9E2D26}" Directory_="APPDIR" Attributes="4" KeyPath="DisplayIcon_1"/>
<ROW Registry="DisplayIcon_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="DisplayIcon" Value="[SystemFolder]msiexec.exe" Component_="DisplayIcon"/>
Is this a problem?
I would have thought that the properties in the AIP should be based upon the registry values that persist, rather than on things that should not persist.
I started investigating these because I noticed that after an install, it left a second row in the Add-Remove programs list, so that my product is listed twice. I fixed that by removing the registry entry and all it's values
Following is an excerpt from my AIP file with the "Uninstall" ones:
  <COMPONENT cid="caphyon.advinst.msicomp.MsiRegsComponent">
    <ROW Registry="CurrentVersion" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion" Name="+" Component_="CurrentVersion"/>
    <ROW Registry="DisplayName_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="DisplayName" Value="[ProductName]" Component_="DisplayName"/>
    <ROW Registry="HelpLink_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="HelpLink" Value="[ARPHELPLINK]" Component_="HelpLink"/>
    <ROW Registry="InstallLocation_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="InstallLocation" Value="[APPDIR]" Component_="InstallLocation"/>
    <ROW Registry="Language" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="Language" Value="[ProductLanguage]" Component_="Language"/>
    <ROW Registry="Manufacturer" Root="-1" Key="Software\[Manufacturer]" Name="\"/>
    <ROW Registry="Microsoft" Root="-1" Key="Software\Microsoft" Name="+" Component_="Microsoft"/>
    <ROW Registry="Path" Root="-1" Key="Software\[Manufacturer]\[ProductName]" Name="Path" Value="[APPDIR]" Component_="ProductInformation"/>
    <ROW Registry="ProductName" Root="-1" Key="Software\[Manufacturer]\[ProductName]" Name="\"/>
    <ROW Registry="ProductName_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="\"/>
    <ROW Registry="Publisher_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="Publisher" Value="[Manufacturer]" Component_="Publisher"/>
    <ROW Registry="Software" Root="-1" Key="Software" Name="\"/>
    <ROW Registry="URLUpdateInfo_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="URLUpdateInfo" Value="[ARPURLINFOABOUT]" Component_="URLUpdateInfo"/>
    <ROW Registry="Uninstall" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall" Name="+" Component_="Uninstall"/>
    <ROW Registry="UninstallPath_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="UninstallPath" Value="[SystemFolder]msiexec.exe /i [ProductCode]" Component_="UninstallPath"/>
    <ROW Registry="UninstallString_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="UninstallString" Value="[SystemFolder]msiexec.exe /i [ProductCode]" Component_="UninstallString"/>
    <ROW Registry="Version" Root="-1" Key="Software\[Manufacturer]\[ProductName]" Name="Version" Value="[ProductVersion]" Component_="ProductInformation"/>
    <ROW Registry="Version_1" Root="-1" Key="Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductName]" Name="Version" Value="[ProductVersion]" Component_="Version"/>
    <ROW Registry="Windows" Root="-1" Key="Software\Microsoft\Windows" Name="+" Component_="Windows"/>
  </COMPONENT>
Re: Disconcerting use of Software\Microsoft\Windows\CurrentVersion\Uninstall
Hello Brian,
Are you saying that after the install, you have two versions installed in the "Add or Remove programs"?
If that's the case, then I can think of two scenarios:
1. you changed the UpgradeCode of your application and therefore it is seen as a new app, not removing the previous one.
2. shared components which do not allow the removal of the previous version
Regarding those entries that you mentioned, please note that those are added automatically in any MSI package. This is how the Windows Installer knows to manage the packages.
Brian Modra
Even on a first time install (from the MSI) - I was getting the two entries in the Add/Remove programs list:
Screenshot 2024-01-05 at 12.22.24 pm.png (62.71 KiB) Viewed 17668 times
The second one is expected (with our Icon). The first is not.
Then if I do this:
reg delete "HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\TopographerWatcher" /f
then I will just see the one (expected) entry in add/remove programs.
This (above) seems like a bit of a hack.
I am wondering if I am missing something.
Hello Brian,
This is indeed quite strange.
If possible, could you please forward me the following resources:
- a copy of the AIP file
- a download link for the MSI setup
by e-mail at support at advancedinstaller dot com so I can run some tests on my end and further investigate this?
