Aswathy Jaganath
An error while installing an application
When we install an application we got an error,
"MSI (s) (18:A0) [23:20:43:532]: Note: 1: 2262 2: CustomAction 3: -2147287038
CustomAction DeleteTPWFolderFromZymark returned actual error code -1 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (18:A0) [23:20:43:559]: Note: 1: 1722 2: DeleteTPWFolderFromZymark 3: C:\Windows\Installer\MSI50FE.tmp 4: /EnforcedRunAsAdmin /RunAsAdmin /dir APPDIR "C:\Program Files (x86)\Sotax\TPW\DeleteTPWFolderFromZymark.vbs" C:\Program Files (x86)\Sotax\TPW\DeleteTPWFolderFromZymark.vbs
Action ended 23:20:45: LaunchFile. Return value 0.
MSI (s) (18:A0) [23:20:56:296]: Product: Sotax TPW -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action DeleteTPWFolderFromZymark, location: C:\Windows\Installer\MSI50FE.tmp, command: /EnforcedRunAsAdmin /RunAsAdmin /dir APPDIR "C:\Program Files (x86)\Sotax\TPW\DeleteTPWFolderFromZymark.vbs" C:\Program Files (x86)\Sotax\TPW\DeleteTPWFolderFromZymark.vbs "
I attached a screen shot of the error happened along with this. Can you please go through it and found out a solution for the error
Image for the error
Image for the error
Re: An error while installing an application
As I see, my colleague Dan has replied to you over the email.
Please continue the conversation there to avoid duplicate threads.
