The ProductVersion is added just in case you plan to have multiple version of Advanced Installer installed.
If you want to change the installation folder, you can simply do so from the installation wizard.
First of all, we have to use the
"Configure" option.
- Screenshot_93.png (52.17 KiB) Viewed 6377 times
Then we need to remove the version from the path:
- Screenshot_94.png (13.9 KiB) Viewed 6377 times
and then the installation folder should no longer contain the version:
- Screenshot_95.png (6.75 KiB) Viewed 6377 times
