AdvInstTester
Error code 0xE000000C during update
Hi Advance Installer team
I am facing an issue during the update. (Advance Installer Version 20.8)
The updater.log file is attached in which we can see the error message : Update installation failed LastError: 0xE000000C but there is no info about this error on your Updater log page https://www.advancedinstaller.com/user- ... dater.html
I am creating an update file and MSI file for x64 OS.
When I check the registry paths, I can see the version key exists on this path: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Manufacturer\Product
While on the following path, the manufacturer name and product name folder exist but Version key does not exist. means the product folder is empty.
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Manufacturer\Product
Please guide.
Regards.
AdvInst UpdateInstallDetectionSetting.jpg (47.27 KiB) Viewed 9429 times
updater.log
(8.78 KiB) Downloaded 530 times
AdvInst Update Error.jpg (23.02 KiB) Viewed 9429 times
AdvInstTester
Re: Error code 0xE000000C during update
While Registry view and text in the Update file are as following
AdvInst UpdateFileView.jpg (33.96 KiB) Viewed 9420 times
AdvInst RegView.jpg (60.98 KiB) Viewed 9420 times
I've replied to your email.
Let's continue the conversation there until we reach a conclusion.
