farmerphd
Security Permissions Blocking MSIX Execution after Installation
After MSIX install on Windows 10, the OS has a user security setting for the User as condition > exists WIN:SYSAPPID contains <MSIX Package Name with Code Signed Extension>. This likely doesn’t match my MSIX package name as set in Advanced Installer because I delete this requirement in Security and installed app works fine.
My question to the Experts is:
How do I control the SYSAPPID entry before building the package with Advanced Installer so it matches the SYSAPPID that Windows expects after install?
Re: Security Permissions Blocking MSIX Execution after Installation
It's not very clear for me the security permission that is blocking your app after MSIX installation, so I would like to take a better look at this.
Could you kindly share your MSIX package with us for a more thorough investigation? You can securely send it to our email address at support at advancedinstaller dot com, ensuring that we have all the necessary details to assist you effectively.
