xObay
Advanced Installer PowerShell Automation Interfaces
how do i set the Product Support Info section using Advanced Installer PowerShell Automation Interfaces?
I can see the the properties for the Product Details on https://www.advancedinstaller.com/user- ... tails.html but I can't seem to find the Product Support Info properties.
Re: Advanced Installer PowerShell Automation Interfaces
Unfortunately, it looks like that is not yet supported.
However, I will add this on our TODO list of improvements and it will be available in a future version of Advanced Installer.
xObay
Can i set those parameters using the command line?
Upon further investigation, it looks like all those fields are controlled via properties.
And of course, we can use both the command line tool and PowerShell to set properties.
For instance, the "Comments" field is assigned the ARPCOMMENTS property.
Additionally, the other fields are also assigned properties that can be seen in the above article on the left:
xObay
How do you set the property using PowerShell?
In order to achieve this, we will use the "PropertyComponent" and then use its' FindProperty method to find and set the property.
