Janusz
Advanced Installer failing to install IIS 11
While installing using Advanced Installer I am getting an error:
"<appname> cannot be installed on systems with Internet Information Services version lower than 7". I looked up internet and none of the solutions works for me. The error indicates that I am installing my app on the system that has already IIS installed with the version lower then 6, but I am installing it on the Windows 11 platform where IIS is not even installed yet. Any help appreciated.
Re: Advanced Installer failing to install IIS 11
If I understand correctly, your setup package that is created with Advanced Installer fails with that error?
If so, please open your project and have a look in the "Launch Conditions" page and make sure there isn't any condition related to IIS.
I'm thinking that perhaps you mistakenly enabled on of those.
Janusz
Thank you so much. This solved my problem.
You are always welcome!
Glad I could help.
