floch
Downloading new updates fails on first install
We use the option to check for updates when running the installer, this causes the download to fail if we run the installer in the default download folder since it can't overwrite the file that started the installation.
We would like an option to choose where the update is downloaded to instead of defaulting to the Download folder.
Re: Downloading new updates fails on first install
If I understand correctly, you need to change the location where the updates are downloaded.
This can be done form the "Updater" page --> "Updater" section --> "Download updates in this folder:"
If somehow this is not what you meant, then please give me some more details so I can better understand.
floch
That does not seem to be honored when using the following option:
Screenshot 2024-01-19 091437.png (6.42 KiB) Viewed 21171 times
Which downloads to the default windows download folder instead of the configured
[AppDataFolder][Manufacturer]\[ProductName]\updates\
I have tested this and I can confirm this behavior as well.
Unfortunately, as for the moment, it is not possible to change that path.
However, this can easily be worked around by having a different name for different versions of your setup (which would be a best practice that we recommend as well). For instance, you can add the [ProductVersion] property in the name of your setup.
We will take into consideration adding an option to change the download folder as well.
You are always welcome! :)
This improvement was added in Advanced Installer v23.1 released on September 25th, 2025.
You ca download our latest version of Advanced Installer from our Downloads page.
