xObay
How to use IDigitalSignature?
Can you please give an example of how to use https://www.advancedinstaller.com/user- ... ature.html?
TIA,
Obay
Re: How to use IDigitalSignature?
Hello Obay,
Thank you for your interest in PowerShell automation support.
Please see the example below:
$advinst = New-Object -ComObject AdvancedInstaller
$project = $advinst.LoadProject("D:\PS support\sample.aip")
$project.DigitalSignature.EnableSigning() = 1
$project.Save()
This example enables the Enable signing option on the Digital Signature page. The "$project.DigitalSignature.EnableSigning() = 0" will uncheck the option.
The below command sets the option to "Use file from disk":
$project.DigitalSignature.SetUseFileFromDisk("D:\mycertificate.pfx")
You can see all supported fields as you type in the PowerShell interface:
PS autocomplete.png (24.13 KiB) Viewed 12924 times
Let me know if you have any questions.
xObay
Thank you for the reply Liviu.
We are using a Yubikey which doesn't work with a PFX file. What is the approach in this case?
Obay
Hello Obay,
As far as we know when you have a YubiKey certificate it should be available in the Personal Store of Current User. You should be able to use the SetUseFromPersonalCertificate method.
$project = $advinst.LoadProject("D:\sample.aip")
$CertificatesList = $project.DigitalSignature.Certificates
foreach ($element in $CertificatesList) {
  if (($element.Thumbprint -eq "8c5a55d94c9d4d6f8b0e8f4644768f00bf65dd2c") -and ($element.Store -eq "User\MY"))
  $certificate = $element
  $certificate
$project.DigitalSignature.SetUseFromPersonalCertificate($certificate)
$project.Save()
Replace the Thumbprint with your certificate Thumbprint. The certificate is identified by Thumbprint in this case, but can use any other property of the IDigitalCertificate object.
  • String Name
    Gets the name of the certificate.
  • String Issuer
    Gets the issuer of the certificate.
  • String Subject
    Gets certificate subject.
  • String Thumbprint
    Gets certificate thumbprint.
  • String DateBegin
    Gets the first date of the valid period.
  • String DateEnd
    Gets the last date of the valid period.
