curt.blunt
Hide a button whilst custom action is running
We would like to disable/hide the 'Install' button on the InstallDlg whilst we do our Licence Validator custom action check, is this possible?
Re: Hide a button whilst custom action is running
Hello Curt,
To achieve this, you should use a "Control Condition" for that specific button.
However, please make sure the button is then enabled. For instance, if your custom action returns success, set a property that can then be used to condition the button being available.
curt.blunt
So I will elaborate on the issue.
Button 1 - has a published action named 'LicenceKeyValidator'
Button 2 - has a published action named 'LicenceKeyValidator'
If an end-user clicks the paste button, it will paste the licence key from clipboard and validate the key at that point
The problem is if a end-user clicks paste button, and then the Install button (button 2) within 1-2 seconds then then 'Install' button doesn't do anything.
I suspect this is because Button 1 is running 'LicenceKeyValidator' and Button 2 also tries to run the same custom action and it can't.
That is why I wanted to attempt to disable the Install button for a few seconds whilst that paste button has been pressed.
So it's technically the same dialog
Hope that helps
Curt
Hello Curt,
Upon further consideration, I think this might not be possible to achieve, as we can not disable a button for just a few seconds. We would have to condition the enabling and disabling it.
What I'm thinking we can do is either:
1. when the paste button is pressed, in our LicenseKeyValidator custom action, we set a property that will disable the Install button. When the action ends, we set another value for that property which should enable the Install button.
or
2. instead of doing executing the custom action on two buttons, add another push button that would say something like "Validate" and execute it only there. Additionally, until the license is correctly validated, have the Install button disabled just like we discussed above.
