badalambadad
Custom Action for a simple db insert doesn't work
I'm having trouble creating an installer with a custom action.
I have followed this sample: https://www.advancedinstaller.com/user- ... et-ca.html
I get this error;
I have this setup;
These are the temp files I'm adding
temp files.png (276.04 KiB) Viewed 16213 times
My custom action is ;
public static int CustomAction1(string aMsiHandle)
MsiSession session = new MsiSession(aMsiHandle);
try {
session.Log("Trying to save license", MsiSession.InstallMessage.ERROR);
var license = new License
StartDate = DateTime.Now,
EndDate = DateTime.Now.AddDays(30),
Type = 0,
HardwareID = session.GetProperty("ProductCode"),
license.Signature = "test signature";//_dataProtectionService.CreateSignature(license);
SaveLicense(license, session);
catch(Exception e) {
session.Log($"Exception of save license is {e.Message}", MsiSession.InstallMessage.ERROR);
session.Log($"Exception of save license is {e.InnerException?.Message}", MsiSession.InstallMessage.ERROR);
return 0;
Has anyone ever had similar issues? I also had a lot of trouble adjusting the references, do I need to put everything in the temp folder and just expect it to work?
Also the debugging isn't working anyhow although I have also attached the .pdb file? Is it not possible to debug when working with temp files?
Thank you!
Re: Custom Action for a simple db insert doesn't work
At a first glance, that seems to be an error thrown by your DLL file - it is not an installer error.
As a first step, you can create a verbose log and see whether that offers more details or not.
In order to further debug it, I would advise using Process Monitor or a similar tool.
If your custom action is executed after the "Add resources" action group in "Custom Actions" page, then please note it's not required to add files as "temporary".
badalambadad
thank you for the answer!
I solved this by managing the dlls and their dependencies.
Regards
You are always welcome!
I am glad you managed to solve this.
