velja
Desktop shortcut icon points to a file on the development machine when the app is installed from appxbundle
Version 21.4. We didn't notice this behavior with earlier versions. Desktop shortcut icon points to a file on the development machine when the app is installed from .appxbundle. It is created after the first start and it displays default icon. When we try to change the icon on that shortcut it displays a warning about the path on the development machine.
image (4).png (132.03 KiB) Viewed 13529 times
velja
Re: Desktop shortcut icon points to a file on the development machine when the app is installed from appxbundle
I deleted and recreated the Desktop shortcut now it points at app dir but that icon file still doesn't exist.
velja
There are more problems. Entry in the Add / Remove programs takes this shortcut name as Product Name. So the name from the Product Details and the Display Name from the Universal Windows -> Package information are ignored and the product is named same as Desktop Shortcut.
I can not say for sure why this is happening.
If possible, could you please forward me the following resources:
- a copy of the AIP file
- download link for the MSIX setup
by email at support at advancedinstaller dot com so I can run some tests and further investigate this?
Hello Velja,
Thank you very much for providing the resources!
I have managed to reproduce them (with the exception of the first one).
On my machine, when I try to change, it points directly to %ProgramFiles% like in your second screenshot.
I have forwarded this to our dev team and I will followup as soon as I will have more information on this.
Thank you for your further patience!
velja
Thanks. Yes, after recreating the shortcut in the last version it is like that i.e. it points to %ProgramFiles%. When we built it with the shortcut as it was in the project file i.e. created in some of previous versions, it pointed to an absolute path on the dev machine. Also, note that the product name is overwritten with this desktop attachment label.
Hello Velja,
You are always welcome!
And yes, I have noticed that the Product Name is replaced by the shortcut name as well.
Hello Velja,
This has been fixed in version 21.7 of Advanced Installer.
