Fellerson
Next button is disabled
Hi Dear
I allow myself to write here because i've an urgent case. I can't install a system by one of our customer because the Next button is disabled.
The setup works perfectly by 99% machine and this machine who is urgent we've an issue.
To explain :
1. In Custom Behavior --> Properties, we defined a new Properties who is "IS_C_DRIVE_OK" with value 0
2. We have a PS script who is checking the free space of the C:\ drive :
Param()
$drive = Get-PSDrive C | where Free -gt 15GB
New-Item "C:\Temp" -itemType Directory
"$(Get-Date) Checking Free space on C:\ drive" | Out-File "C:\Temp\Set.log" -Append
New-Item "C:\Users\Public\Desktop\Tools" -ItemType Directory
"$(Get-Date) Tools folder in Public Desktop created" | Out-File "C:\Temp\Set.log" -Append
New-Item "C:\Users\Public\Desktop\Running Version" -ItemType Directory
"$(Get-Date) Running Version folder in Public Desktop created" | Out-File "C:\Temp\Set.log" -Append
AI_SetMsiProperty IS_C_DRIVE_OK $drive.Count
3. On our Dialog, we've an Init Events who is "Execute custom action" with Argument "PowerShell_Check_Disk_Space" (script just before) with condition 1
The Nesxt > butotn stays disabled even if i've enough free space.
I compare the logs between 1 machine where it's working perfectly and this machine.
The following line is missing :
MSI (c) (28!6C) [08:44:19:829]: PROPERTY CHANGE: Modifying IS_C_DRIVE_OK property. Its current value is '0'. Its new value: '1'.
The 7 following lines are also missing on the server where it doesn't work
MSI (c) (28!EC) [08:44:17:532]: PROPERTY CHANGE: Adding PreReqSearch_A918597FE054CCCB65ABDBAiVerFound property. Its value is '14.32.31326'.
MSI (c) (28!EC) [08:44:17:532]: PROPERTY CHANGE: Adding PreReqSearch_A918597FE054CCCB65ABDB property. Its value is '14.32.31326'.
MSI (c) (28!EC) [08:44:17:532]: PROPERTY CHANGE: Adding PreReqSearch_C4FE6FD5B7C4D07B3A313EAiVerFound property. Its value is '14.32.31326'.
MSI (c) (28!EC) [08:44:17:532]: PROPERTY CHANGE: Adding PreReqSearch_C4FE6FD5B7C4D07B3A313E property. Its value is '14.32.31326'.
MSI (c) (28!EC) [08:44:17:548]: PROPERTY CHANGE: Adding PreReqSearch_1_A918597FE054CCCB65ABAiVerMin property. Its value is '14.30.30704'.
MSI (c) (28!EC) [08:44:17:548]: PROPERTY CHANGE: Adding PreReqSearch_1_A918597FE054CCCB65ABAiVerFound property. Its value is '14.32.31326'.
MSI (c) (28!EC) [08:44:17:548]: PROPERTY CHANGE: Adding PreReqSearch_1_A918597FE054CCCB65AB property. Its value is '14.32.31326'.
I already try everything :
- Regedit access is OK
- User Account have Full Admin Rights
- Run As admin
I've a custom log where i'm writing ("Set.log" and i can see it works
I'm really lost. I hope somebody can help. Ty.
Re: Next button is disabled
Hey Steve,
From what I can see, you have the same discussion with my colleague Eusebiu over the email.
Please continue the thread there and, if possible, try to avoid duplicating the same thread over the forum as well if you sent an email.
