Jossy Jose
Log File Saving in custom location
How can we save the verbose log files into a custom location with custom name. Especially when throwing the errors, have to save or copy the verbose log files into custom location with custom names.
How can we make it possible.
I am using Advanced Installer 21.1.
Re: Log File Saving in custom location
If you want your installation package to always create a log, you can follow these steps:
1. go to the Builds page and select the Configuration tab
2. set the MSI Command Line field to: /L*V "C:\package.log" (this is only available for EXE packages)
This way, when the user launches the installation through the bootstrapper, an installation log ("package.log") will be created automatically in the "C:\" drive.
You can also use properties for system folders: /L*V "[LocalAppDataFolder]customlog.txt"
log command.png (8.7 KiB) Viewed 5075 times
However, the folder you are using must exist before launching the installation. The log command is handled by Windows Installer module and it cannot create folders. This means that if you specify a log file location that does not already exist, the installer will not be able to create it and the logging will fail.
