cuthbertdavies
Multiple Instance not working
Hi
I created a installer with multiple features and enabled the Multiple Instance s Feature (Generate instances at installlation time = X).
When I try to install a second installation and I select "Install new Instance" a window apears and disapeaere imediatly and the "Modify Repair" Dialog is hown after.
Re: Multiple Instance not working
This is quite strange.
To facilitate a more in-depth investigation of this issue, could you kindly email the following resources to support at advancedinstaller dot com?
1. the .AIP (setup project) file
2. a download link for your setup package
3. the build number and version of the machine's operating system where you can reproduce this
