alter_ego_dev2
How to customize Advanced Installer prerequisites?
We would like to have two different installer versions of an application.
1). An installer has several prerequisites based on "Download single file from URL" approach. The installer size is small and it can download prerequisite files during installation and install them before application.
2). The second installer will be executed in the environment when an installer can't download prerequisites. Probably, prerequisite files should be included as resource files and used in the Prerequisite section as "Use files from disk". In this case, installer size is much bigger, but doesn't require an internet connection.
Since the app installer project has a lot of settings, custom actions and will be changed frequently, it is reasonable to have only one installer project. I am wondering what would be the best practice to handle such scenario?
Probably, I could add a different build, set different properties for each build. Can I add a file to Resource conditionally? For example, Build B has a large prerequisite file, a prerequisite setting use this optional file. Build A doesn't have a large file, prerequisite installation is disabled and overall installer size is smaller. Is it possible?
Re: How to customize Advanced Installer prerequisites?
In this case, I would suggest using the "Save as Template" option.
We can create the base project (with all the customizations, except for prerequisites).
We can then, based on the above template, generate two projects:
- one with the prerequisites embedded
- one with the prerequisites downloadable online
You can, for easier access, create a "project solution" (e.g. a solution containing your two projects).
To do so, open one of your projects, go to "File" --> "Add" --> "Existing project to solution".
And then, to save the solution, you can go to "File" --> "Save" --> "Save Solution as"
alter_ego_dev2
Thank you very much for the clarification!
I've got a question from the maintainability perspective: If I understood correctly there are two projects created from one template in your proposed option. Does it mean that in case of a new custom action, I will need to create a custom action in one project and then create the same custom action in the second one?
You are always welcome!
Yes, that is indeed the case. In order to simplify this, you can copy-paste the custom action, but yes, it would need to be added in both projects.
Just a short addendum to your original question: how to configure in the same installer prerequisite items per build.
Starting with newer versions of Advanced Installer this could be easily accomplished and configured. All you have to do is to create multiple builds in "Builds" page of your setup project, e.g.
And then in "Prerequisites" view use the "Builds" tab of your prerequisite item to select the build you want it included in.
