stefan_riediger
XML is not updated in a "Modify" Maintenance Installation
Dear Advanced Installer Support team,
Problem
After an "Modify" Maintenance Installation the XML is not updated with the modified value
Description
I have attached a simple Project to reproduce the error.
The Project contains an XML file data.xml with an element root/key, where the value is associated with a property [MYVALUE]
<?xml version="1.0" encoding="UTF-8"?>
<root>
  <key></key>
</root>
I have added an Edit field on the VerifyReadyDlg and set the Property Name to [MYVALUE].
The intention is that after the installation, the installation folder contains the data.xml with the value which I have entered in the edit field.
That works perfectly fine.
Now I run the setup a second time and select Modify option on the MaintenanceTypeDlg.
I follow the steps until the VerifyReadyDlg , but now I enter a different value.
The problem is that when I look at the XML file, the value is not updated.
I have attached the project MyApp3.aip.
I'm using Advanced Installer 21.4
I have also made a 15 MB Video. The link is valid until 2024/3/13
https://magentacloud.de/s/GE4SmcoSD2MTdXA
Password:
NxeTKZPB
I have followed the steps on https://www.advancedinstaller.com//user ... uestion256
And also tried different settings, but I didn't get it work.
I hope you can help me.
best regards,
Stefan
MyApp3.aip
(17.33 KiB) Downloaded 237 times
Re: XML is not updated in a "Modify" Maintenance Installation
Hello Stefan,
That might be happening because the feature that contains the file is not actually "reinstalled" so it overwrites the old value.
To achieve what you want, you can proceed as it follows:
- in "Components" page, move the data.xml component to a new feature, let's call it Data
- then, on the "VerifyReadyDlg" dialog, we can add a new event, as it follows:
This way, we can ensure that the file is reinstalled and the new value will be there.
stefan_riediger
thank you very much. Your instructions work perfectly. :)
best regards,
Stefan
You are always welcome, Stefan!
Glad I was able to assist. :)
