zander1989
Adding entire folder to windows defender exclusion
Is it possible to add the APPDIR to the windows defender exclusion list?
I am running this custom PowerShellScriptInline:
Add-MpPreference -ExclusionPath [APPDIR]
But it just doesn't work it adds APPDIR only instead of the path, any suggestions? Not so good with powershell
Re: Adding entire folder to windows defender exclusion
To get a property value in a PowerShell Script custom action, please check our Getting a property value into a script article.
PS property.png (108.35 KiB) Viewed 11712 times
Hope this helps! Let us know if you have any other questions.
You're always welcome!
