CaMat
Password edit box displays text after disabling it
After updating Advanced Installer to version 21.5 I noticed that edit box with password option enabled shows text when I disable it. Example:
GIF 12.03.2024 12-53-24.gif (18.17 KiB) Viewed 7973 times
Events defined on password edit:
Screen capture.PNG (8.42 KiB) Viewed 7973 times
To reproduce this, I created new project with Vivid theme. Next, in dialog I added radio buttons and edit box with password option enabled (rest of options I left default). After that I added events to edit box like in a picture above.
Probably theme is irrelevant becasue I can reproduce this behaviour on another themes.
I saw there is a new version of Advanced Installer (21.5.1) but in release notes there is no information about this. I don't know if this problem was on previous versions.
Is there any fix to this behaviour?
Re: Password edit box displays text after disabling it
I have tested this with a sample project and I can indeed confirm the behavior.
I have forwarded this to our development team and hopefully this will be fixed in a future version of Advanced Installer. As soon as the fix will be released we will notify you.
A fix for this is now available in version 21.6 of Advanced Installer.
