moussaoui
Remote install freeze at AI_VerifyPrereq
The remote installation freeze occurred at the AI_VerifyPrereq part in the hyper-v guest VM. The prerequisite was uninstalled just before the freeze started, and there was no error message in the log file.
MSI (s) (98:D8) [16:49:00:756]: Doing action: AI_VerifyPrereq
Action start 16:49:00: AI_VerifyPrereq.
MSI (s) (98:F0) [16:49:00:756]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI2716.tmp, Entrypoint: VerifyPrereq
to reproduce: Once the MSI has been copied to the Hyper-V guest virtual machine, run this command line in hyper-v host
Invoke-Command -VMName virtual-machine1 -Credential $DCLocalCredential -ScriptBlock { Start-Process -FilePath 'msiexec.exe' -ArgumentList '/i "C:\path\to\package.msi" /qn' -Wait }
advanced installer version: 19.6
N.B: This error is only present in remote mode.
Re: Remote install freeze at AI_VerifyPrereq
In order for me to further test and investigate this, could you please forward me a more detailed test-case?
From my understanding so far:
- I need to remotely invoke msiexec to install an MSI on a VM
- that MSI need to have a prerequisite
Is this all? I'm mostly asking because of this line:
Was the prerequisite already installed and you manually removed it beforehand?
moussaoui
Hello Catalin,
- the MSI install the prerequisite and then uninstall them after that the installation freeze
- AI_VerifyPrereq should return value 3 and trig a rollback since the prerequisites are missing, instead the MSI installation freeze
- the main issue is remote install an MSI on a hyper-v VM, I can install the MSI manually or silently but not remotly
nothing is already installed in the VM
What I find a bit confusing is this:
Could you please ellaborate more on this? How is the prerequisite installed and then uninstalled during the same installation process of the main package?
Or even better, do you think you could provide a sample project that reproduces this? You can send it by email at support at advancedinstaller dot com.
Here's what the sample project would consist of:
- the AIP file for the main package
- the AIP file for the prerequisite (only if you create it using Advanced Installer)
- the download link for the main package
