Nermendis
Installation route
Hello
I would like to ask for help. I've done a lot of searching on the subject, but I can't find it.
I want to run a bat file that will find the installation path, save it to a registry key. I then set APPDIR to this value from the key.
However, it seems that the scanning of the "registry key" always happens before the bat file is run.
How can I do this? The target location can be in 2 places, so I need to find it before installation.
Thank you! And excuse my English.
Re: Installation route
Indeed, the search you have configured is executed during the "Search" action group from the Custom Actions page.
What you can do to work this around is doing the search thorugh a custom action and then using the respective command to set the APPDIR property.
How to set an installer property using custom actions
I have to admit that this scenario is quite strange to me. Could you please let me know how that bat file is finding the installation path?
I'm asking because we can perhaps find an easier way to achieve what you ened. :)
Nermendis
The bat file first looks for a mod folder for the program (this may contain translations), if it doesn't find it, it looks for the folder where the program is installed.
Rem @for /f %%i in ('WHERE /R C:\ strings.po') do @set foC=%%i
@for /f %%i in ('WHERE /R D:\ strings.po') do @set foD=%%i
REG ADD "HKCU\Software\installFolder" /v "InstallLocation" /t REG_SZ /d %foD% /f
All around this is what the bat file currently looks like, it now finds 1 route successfully.
Nermendis
I also found an earlier article that you cannot return a value with a batch file. On your recommendation, I wrote an inline PowerShell script to give a value to my own property, and it works perfectly! Thanks for your help!
You are always welcome, glad to hear everything is working as expected.
