Natraj
YubiKey not asking for PW
Hi all, I create exe file using Advanced Installer and I use YubiKey to sign the exe digitally. It worked until last week without any issue. Today, it is not asking for the password to create exe. When I use the exe what was generated it says Unknown Publisher.
I tried removing the YubiKey, and I saw a prompt that YubiKey is missing. Even though I plugged it back in it is till not asking for the PW. I even restarted the machine a couple of times.
I am using Windows 11 Pro Build: 22631.3296
Any suggestions on what I am missing? Thanks so much
Re: YubiKey not asking for PW
Hi and welcome to our forums,
I have tested the scenario but I cannot replicate the behavior.
Can you please tell us what version of Advanced Installer are you currently using?
Also, can you please try removing your certificate from your Yubikey USB dongle, then removing it from your Windows machines certificates store (e.g. Local Machine and User stores) and then import it again on your YubiKey dongle?
Finally reconfigure again "Digital Signatures" page into your setup project and see how this works now.
